[Dashboard] How to use controls?
This flow includes one button node, one dropdown node, one switch node and one slider node. Those controls has been triggered or changed, they will send the relative info to debug node for review or further processing。
dashboard controls 1
dashboard controls 1.PNG (6 KiB) Viewed 24312 times
dashboard controls 2
dashboard controls 2.PNG (22.37 KiB) Viewed 24312 times
Flow:
[{"id":"5a5e0776.30c7b4","type":"tab","label":"AIC IoT Studio - Gauge","disabled":false,"info":""},{"id":"a9a9c052.9068f8","type":"ui_button","z":"5a5e0776.30c7b4","name":"","group":"23d3e331.b3cf3","order":1,"width":4,"height":1,"passthru":false,"label":"Button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"Button clicked","payloadType":"str","topic":"","x":330,"y":80,"wires":[["2ddc1704.baa19"]]},{"id":"373eeef6.11653c","type":"ui_dropdown","z":"5a5e0776.30c7b4","name":"","label":"Dropdown","tooltip":"","place":"Select option","group":"23d3e331.b3cf3","order":2,"width":4,"height":1,"passthru":true,"multiple":false,"options":[{"label":"item1","value":"item1","type":"str"},{"label":"item2","value":"item2","type":"str"},{"label":"item3","value":"item3","type":"str"}],"payload":"","topic":"","topicType":"str","className":"","x":350,"y":140,"wires":[["2ddc1704.baa19"]]},{"id":"645a91ce.9d508c","type":"ui_switch","z":"5a5e0776.30c7b4","name":"","label":"Switch","tooltip":"","group":"23d3e331.b3cf3","order":3,"width":4,"height":1,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":330,"y":200,"wires":[["2ddc1704.baa19"]]},{"id":"dbb8e1ed.7f0e58","type":"ui_slider","z":"5a5e0776.30c7b4","name":"","label":"Slider","tooltip":"","group":"23d3e331.b3cf3","order":4,"width":4,"height":1,"passthru":true,"outs":"end","topic":"","min":0,"max":10,"step":1,"x":330,"y":260,"wires":[["2ddc1704.baa19"]]},{"id":"2ddc1704.baa19","type":"debug","z":"5a5e0776.30c7b4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":550,"y":160,"wires":[]},{"id":"23d3e331.b3cf3","type":"ui_group","name":"Controls","tab":"a9f1a261.231458","order":2,"disp":true,"width":8,"collapse":false},{"id":"a9f1a261.231458","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
