Search the forum before posting
Before opening a new thread, search the forum. Maybe someone else has had the same problem and your question has been already answered. If you find a topic that covers your problem, but you have further questions, post your questions there. But only do this if you really have exactly the same problem. If it's only somehow related, open a new thread.
Choose a meaningful title.
Your title should reflect the core of your problem, so that we and other users know what your question is about.
Open a separate thread for each question.
If you have more than one problem, start a new thread for each. This makes it easier to discuss and improves the readability of the forum. Keep in mind that others may encounter the same issue later.
Choose the right subforum.
We have a separate area in the forum for each of our products. Pick the one that covers the product you are using.
Give some context.
Before describing your problem in detail, give a short overview of your project, e.g. what kind of application you're working on, what platform you're using etc.
Describe your problem carefully.
To be able to help you, you have to give us all the relevant information to reproduce your problem.
We need at least the following information about the product.
- name of the product
- version number (e.g. 1.5.3)
- operating system
Use correct and simple English.
Keep in mind that we have to understand your question to give you an helpful answer. So do your best to write correct and simple English. Use short sentences.
Be patient.
We try to answer all questions as soon as possible, usually within a few days. Do not panic if you don't get an answer within a few hours. Keep in mind that there might be such things as holidays etc.
