[Control] Call Web Service by VideoWall Remote Controller
Presentation of the VideoWall includes: Control, Design and Scenarios.
Moderator: VideoWall Support
VideoWall Support
Post by VideoWall Support »
The VideoWall Remote Controller can call VideoWall Web Service do commands.
Remote Controller.PNG (8.22 KiB) Viewed 44947 times
VideoWall Settings
[Note]: before do remote control to make sure the target VideoWall Utiltiy Option Web Service is ENABLE.
  • VideoWall IP
    This ip address is the target VideoWall Web Server IP.
    Note: you should check can ping the VideoWall Web Service.
  • Service Port
    This Service Port is same as the target VideoWall Option Web Service Service Port value.
    Note: you should check the VideoWall Web Service port did't been blocked by system FireWall.
  • Service Token
    This Service Token is same as the target VideoWall Option Web Service Security Token value.
Remote Controller Commands
Those commands most are same as VideoWall Utility Scene Page Hotkey Settings defined except the NAMR_PAGE, HTTP_CFG and FILE_CFG.
Operation is to select the Command and set the needs Parameter then press Send buton to target VideoWall Web Service do action.
  • PLAY
    Same as Hotkey Ctrl + Shift + P. No Parameter need.
  • FIRST
    Same as Hotkey Ctrl + Shift + Up. No Parameter need.
  • PREV
    Same as Hotkey Ctrl + Shift + Left. No Parameter need.
  • NEXT
    Same as Hotkey Ctrl + Shift + Right. No Parameter need.
  • LAST
    Same as Hotkey Ctrl + Shift + Down. No Parameter need.
  • EXIT
    Same as Hotkey Ctrl + Shift + E. No Parameter need.
  • DEMO
    Same as Hotkey Ctrl + Shift + D. No Parameter need.
  • MEDIA_PLAY
    Same as Hotkey Ctrl + Alt + P. No Parameter need.
  • MEDIA_MUTE
    Same as Hotkey Ctrl + Alt + M. No Parameter need.
  • N_PAGE
    Same as Hotkey Ctrl + Alt + 1~Ctrl + Alt + F.
    The Parameter is the scene number start from 0 to 14. ex the Scene 1 Parameter is 0, the Scene 15 Parameter is 14.
  • NAME_PAGE
    Every scene has scene name use in Parameter field.
    Ex scene 1 name is 'Facility' then set Parameter is 'Facility'. Press send button will let the target VideoWall change to show the Facility scene.
  • RELOAD
    Same as Hotkey Ctrl + Shift + R. No Parameter need.
  • HTTP_CFG
    This command can change the target VideoWall Scene Config by download the new scene config from http server.
    The Parameter set the download url.
    Formate prefix must be "http://"
  • FILE_CFG
    This command can change the target VideoWall Scene Conofig by select the target VideoWall local Scene Config file.
    The Parameter set the local Scene Config file name in working directory.
    Formate prefix must be "file:///"
Best Regard,
VideoWall Support Team
