The Endpoints page allows you to configure all affiliated settings of connections between endpoints. You can edit the settings and save them by clicking Apply at the bottom of the user interface. The settings are applied once the server has been restarted.
Appliation URI: UA TCP is the default network protocol for the endpoints.
Port: Enter a number in the Port field to set the dedicated port for the connection address.
Server Name: Enter a name in the Server Name field to set the hostname for the connection address.
Security Modes: Check either of the check boxes in Security Modes to set the method for authenticating the connection.
- None: The connection does not require authentication.
- Sign: The connection requires sign-in information.
- SignEncrypt: The connection requires and encrypts signin information.
Security Policies: Check either of the check boxes in Security Modes to set the method for authenticating the connection.
- Basic128Rsa15: The connection adopts RSA15 as the key wrap algorithm and 128-bit Basic as the message encryption algorithm.
- Basic256: The connection adopts 256-bit Basic as the message encryption algorithm.
- Basic256Sha256: The connection uses SHA256 for the signature digest and 256-bit Basic as the message encryption algorithm.
