Page 1 of 1
[User Manual] Introduce Users
Posted: Mon Nov 21, 2022 5:50 am
by OpcUa Support
The Users page displays user authentication settings. Connections to AIC OpcUa Server can be authenticated with username/password, Windows Logon, or Certification.
1. Reset:
Click Reset to change the password of the Administrator.
2. Server Users:
Right click on the table in Server Users to Add a user, Delete one or multiple users, Change Password of a user, and Change Access Right of a user.
Note:
Press and hold the Shift key and click on the name of the user to select multiple users.
- Add User
Select Add User in the pop-up window to add a new account. Enter the required information in the respective fields, and select the required Access Right option by selecting the respective checkboxes. Click OK when done.
3. Enable Windows Logon:
Check the checkbox on the left of Enable Windows Logon to enable or disable Windows logon, which is a feature
that uses username and password of the local windows installation for AIC OpcUa Server connection.
4. Enable Certification:
Check the checkbox on the left of Enable Certification to enable or disable asymmetrical cryptography to authenticate with the self-signed certificate for AIC OpcUa Server connection.
The trusted self-signed public key is stored in the following path:
C:\Program Files\NEXCOM\AIC OpcUa Server\pkiuser\trusted\certs
The rejected self-signed public key is stored in the following path:
C:\Program Files\NEXCOM\AIC OpcUa Server\pkiuser\rejected
Note: Moving a rejected self-signed public key from the “rejected”
location to the “trusted” location results in its status becoming trusted.
5. Anonymous:
Check the checkbox on the left of Anonymous to enable or disable anonymous login.
