[User Manual] Introduce Installation, Launch, Uninstallation
Posted: Fri Nov 18, 2022 6:07 am
1. Installation
1.1 Double click on the filename of the AIC OpcUa Server setup file, select the language for the installation, and click OK. 1.2 The installation wizard will prepare the setup process. 1.3 Click Next to proceed, or click Cancel to quit. 1.4 Check the I accept the terms in the license agreement option, and click Next to proceed. 1.5 Enter the user information. Note:
You can use the Trial Version option and enter the serial number later. The entered product key will introduce a respective version of AIC OpcUa Server displayed on the title of the GUI. *A warning message will be prompted if the serial number is invalid.
1.6 Click Install to begin installation. 1.7 The installation will begin and may take a while. 1.8 Once completed, click Finish to exit the installation wizard. 2. Launch
Once installed, you should be able to find the program named AIC OpcUa Utility in the All Programs list as shown. 2.1 Click on the icon or AIC OpcUa Utility to launch the AIC OpcUa Server.
2.2 Enter the password in the respective field and click OK. Note:
1. Use the default Password: 0000 to log in if you are logging in for the first time.
2. Remember to change the password frequently and keep it in a safe place to avoid hacking. Refer to License for setting the password. *A warning message will be prompted if an incorrect password is entered.
2.3. The GUI of AIC OpcUa Server will be displayed on the screen.
3. Uninstallation
3.1 First, click System\Settings\Apps. 3.2 Click Apps & features and "AIC OpcUa Server" 3.3 Click "Uninstall" to uninstall the application.
3. Uninstallation
