OpcUa Extender Server:如何當Modbus Client 、 OPC UA Client 使用等?
  • 當 Modbus Client 使用。
Environment:
  • modsim32
  • OpcUa Extender Server
  • UaExpert/IoT Studio
Step 1:
Utilize modsim32 to create a Modbus TCP device.
Step 2:
Launch OpcUa Ext. Utility, then select the "Industrial Protocol" tag.
Add a "Modbus Tcp Configuration".
Prepare a Modbus device nodes config file for access and add it in the "Modbus Tcp Configuration".
Example: Modbus device nodes config file
;TagName , DisplayName , Directory , Type , Trans , Address , Length , Factor , Offset
"TagString_4_40100","TagString_4_40100","InputReg/STRING","STRING","",40100,4,,
"TagString_4H_40100","TagString_4H_40100","InputReg/STRING","STRING.H","",40100,4,,
"TagString_4L_40100","TagString_4L_40100","InputReg/STRING","STRING.L","",40100,4,,
"TagString_4_30100","TagString_4_30100","InputReg/STRING","STRING","",30100,4,,
"TagString_4H_30100","TagString_4H_30100","InputReg/STRING","STRING.H","",30100,4,,
"TagString_4L_30100","TagString_4L_30100","InputReg/STRING","STRING.L","",30100,4,,
After configuring Modbus TCP, apply the changes, then restart the OpcUa Extender Server.
Step 3:
Utilize UaExpert to connect to OpcUa Extender Server, locate the Protocols in the relative Modbus TCP folder.
Then, you can read/write to the Modbus TCP device like a Client.
  • 當 OPC UA Client 使用。
  • Another OpcUa Extender Server/other OpcUa Server
Step 1:
Utilize OpcUa Extender Server to create a target OpcUa Server.
Then got the target OpcUa Server Endpoint like: opc.tcp://os-x:48010
Step 2:
Add a "OPC UA Client".
Prepare a OPC UA Client nodes config file for access and add it in the "OPC UA Client Configuration".
Example: OPC UA Client nodes config file
Int32_Var01,Int32_Var01,,INT32,,ns=2;i=6003,1,,
Int32_Var02,Int32_Var02,,INT32,,ns=2;i=6004,1,,
Int32_Var03,Int32_Var03,,INT32,,ns=2;i=6005,1,,
Int32_Array,Int32_Array,,INT32,,ns=2;s=Tags.TagType.INT32.TagInt32_Arr[4],1,,
Float,Float,Float,FLOAT,,ns=2;i=6012,1,,
Verify the OpcUa Server is Exist, press the "Connection Test" button.
After configuring OPC UA Client, apply the changes, then restart the OpcUa Extender Server.
Step 3:
Utilize UaExpert to connect to OpcUa Extender Server, locate the Protocols in the relative OPC UA Client folder.
Then, you can read/write to the OPC UA Client like a Client.
