The below is a javascript sample code for reference:
Code: Select all
const http = require('http');
const https = require('https');
function doPost(url, _data, _headers)
var uri = new URL(url);
const { request } = uri.protocol === 'https:' ? https : http;
// Define the data to be sent in x-www-form-urlencoded format
//const data = 'client_id=node-red-admin&grant_type=password&scope=*&username=admin&password=admin';
// Define the options for the POST request
const options = {
hostname: uri.hostname, // Replace with your target URL
path: uri.pathname, // Replace with the specific endpoint you're targeting
method: 'POST'
if (uri.port) {
options.port = uri.port; // Replace with the appropriate port if necessary (e.g., 443 for HTTPS)
} else {
options.port = uri.protocol === 'https:' ? 443 : 80;
options.headers = _headers;
return new Promise((resolve, reject) =>
// Create the request object
const req = request(options, (res) => {
let responseData = '';
// A chunk of data has been received.
res.on('data', (chunk) => {
responseData += chunk;
// The whole response has been received.
res.on('end', () => {
resolve(responseData);
// Handle errors
req.on('error', (e) => {
reject(`Problem with request: ${e.message}`);
// Write the data to the request body
req.write(_data);
// End the request
req.end();
function getToken()
var url = new URL("http://127.0.01.1:10200/auth/token");
const _data = 'client_id=node-red-admin&grant_type=password&scope=*&username=admin&password=admin';
let _headers = {
'Content-Type': 'application/x-www-form-urlencoded',
'Content-Length': Buffer.byteLength(_data)
return new Promise((resolve, reject) => {
.then((res) => {
resolve(res);
.catch((resason) => { reject(resason);});
getToken().then((token) => {
console.log(JSON.parse(token));
